No loss release chuck?
If I fill a bladder w/o it, how much pressure loss there might be? Is it pointless to try to fill a bladder w/o it?
Lots. Definitely need to use one otherwise there's no way of telling how much pressure you ended up with.
i think russ did some tests and found very little pressure loss.
i'm interested too in how much others found that it's lost. With my chuck i'm losing aprox 0.8-1 bar
Set the nitro tank regulator at 170psi while pressurizing the rezzy with a standard schrader type adaptor and you will lose about 20psi ending up around 150psi in the rezzy which is probably the average setting.
I don`t even use my gauge for filling CRF`s and YZF`s any more:ride: Just the odd ball stuff.
if you keep the pressure on as you remove the chuck i cant see how much can escape?
So you don't even need the 200 dollar isolation valve? I was always told that since it is such a high pressure but little volume that you should not use a standard schraeder. I guess that still would not solve my problems with oil filling.
I have checked and I only lose 5lbs when each time the valve is depressed. So, if I am filling a bladder I set my gauge 5lbs high of what I want, and pull away (close the valve) once.
A lossless chuck can be had for $35. I bought one assembled with a hose, valve and gauge for $70.
When I filled my shock I did it about 5 or 10 times. Each time I would fill it, check it, then check it again. I lost about 10 psi every time I checked it, so I set the regulator to get 160 psi on the first check.
Where????!!!
http://www.powertank.com/products/sfID1/29
I bought the SIG-500 and it works fine. I use the regulator gauge more than the gauge on it though. There is also an aircraft supply place that has the lossless chuck. I forget the name though. IIRC its the same price as from Power Tank though.
the trouble is they dont fit all shocks, some shocks have a deep recess.
I get 5-10PSi loss
I measure the pressure with a tyre guage after chuck removal.
cut a length of fuel line to fit into the guage chuck so the guage only just depresses the shrader then loss from measuring is only 1 PSI max.......
maybe I need to do the same thing with the filling chuck
a guy on hberg.org put a bolt in the schrader valve tube inside the shock to restrict flow so filling the shock takes about as long as filling a car tyre.
result is that pressure loss is minimal but its a PITA to set resovoir piston height.
it just seems too much hassle for a possible 5psi drop to me, i think its great people go to all the trouble but i dont feel the need.
Where did you get that assembly?
