03YZ125 ShockSpring Removal
Help,
I cant find any info on how to remove the the rear shock spring. I bought new shock and fork springs from race tech to help set up my sons bike for his weight but can't find any how to's on spring removal and replacement.
Thanks,
Red
easiest for you - as long as you don't have a spring compression unit - is to measure the spring length and then open the castle nuts as if you were adjusted the sag.
Turn them screws loose then you can push down the sleeve at the clevis and pull it off.
