xr250 wheels for xr600?
hey guys,need some help. ive found someone parting a 03xr250. i neen a set of tyres for my xr600,will the 250 gear swap atraight over?
Almost.
The rear sprocket on the XR250 has a different offset by about 5mm. This causes the sprocket to rub the chain guard and wear the chain/sprockets funny/quickly.
The front axle on the XR250 is also 17mm rather than 19mm.
Not saying it won't work as I run my XR650L sumo wheels on my XR250 all the time.
One time I even ran the XR250 rear dirt wheel on the XR650L.
different parts can "work", or be made to work, but if you're looking to find what bikes had the SAME parts as yours, go to -powersportspro.com-
open it in 2 different windows.
search your 'rear wheel hub' for your bike in the first page.
then tab over, and do a "quick part lookup" of that hub's part # in the second page.
it will tell you every honda that came with that same hub. then check the disc. then the bearings. then the......... ?
and remember, if Honda makes an identicle part for 2 years, but they paint it a different color, they give it a different part #.
