cam/rocker gasket
hi guys
my new rocker gasket keeps leaking am i meant to use some gasket sealent on it ??? the 2 parts that sit on the cam sproket side are leaking, would use my manual if i knew where it was :)
next time i will use the search facility !
you will need some black gasket sealant to fit the rocker cover gasket, everything else should be in your spares kit. make sure she is clean before you start, i would remove the tank when you wash it as a lot of crud gets onto the rocker cover etc.
