Rear Flippin Brakes !!!!!!!!!!!!!!!!!!!!!
SO I JUST PICKED UP A NEW REDCAT DZ150 YESTERDAY,,,,
rear brakes arent working ,,ive been bleeding for the last 4 hours !!!!!
ive tried every possible way ive found on here,,,except vacuum,,,,
can some one help me out here before i go any more nuts:banghead: :):banghead: :banghead: :foul::p
ive tried to reverse bleed and cant even pump the fluid in !!!!
WHAT THE HELL AM I DOING WRONG !?!?!?!
THEY DONT MOVE AT ALL !!!!!
The brake might just not work :) ! Try Chinariders.net and see what the members can help you out with. www.jetmotousa.com has brakes, too, for most Chinese bikes (they are all pretty much the same)
The rear brake on one of mine didn't work, like you i bled and bled, still no good.
then a mechanic friend told me to grease the pins on the sliding part of the caliper (under the rubber boots) worked fine after that.
Had just seazed on the pins.
Regards.
Mike.
post a pic of this bike, I've had quite a few problems with the brakes on my chinese pitbike.
if you have one with a crf based engine, check your footpeg-bar and brakelever clearence, the bar tends to bend over time, this causes it to depress the brakelever ever so slightly, causing you to eventually lose all pressure.
if the bar is touching the lever, grind a notch in the lever where it contacts the bar, and when you bleed it, LIFT the lever all the way up before you depress it.
