wr250f 2002-2003 engine swap??
Hi guys.. ive got a 2002 wr250f and the engine is in a bad way.. i want a bike with electric start (2003 and newer models do have this) so my options are to sell it and get a newer bike.. or to replace the 2002 engine with a 2003 engine with electric start.. - however this is dependent on the 2003 engine fitting my 2002 bike.... so my question is "can i stick a 2003 engine in my 2002 wr250f?"
The rear motor mount that the swingarm bolt passes thru,is smaller on the 02 than it is on the 03.The oil tubes will line up fine.the 02 has a smaller crank,so the flywheels will have to remain w/ the respective bikes.The neutral switches are also different as well as the carbs.
