2004 kx125 forks question
Ok i have a 2004 Kawasaki kx125 and i just noticed that the right fork seems to be up higher than the left fork... and im not sure how it happened or how to fix it... any help would be appreciated, thanks. :foul::):p:banghead: :banghead: :busted::crazy::lol:
Loosen your triple clamps and reset your fork tube height 5 mm's from the top of the top triple clamp from the bottom of the fork cap you should be measuring fork tube not tube and cap. While it's apart anti sieze your triple clamps bolts and torq 14 lbs bottom pinch bolts 17lbs top pinch bolts.
i`m trying to get to the shim stack,can`t get the bottom apart.
i can turn the thing at the very bottom ,but it don`t screw out.
forks are too hard.i want them soft for harescrambles.
i don`t have any money to spend.
Look in the manual and but the special tool.
