2006 YZ250F spring rate
my stock Ti one was like a 5.2 i think and i believe thats like 180lb rider.
Its stiff probably good for you. Just try setting the sag. If you can't you may want to get another.
Im not sure on the wieght just know it was way to stiff for me lil 150lbs
They had 4.4 in the front fork and a 5.1 Ti shock spring. I'm around 180 w/o gear and I run a steel 4.7 rear and 4.3 in front. The 4.4 in front worked fine I just changed mine experimenting a little.
try it out. see what your sag is.
You should be fine with that spring. You'll probably start dropping pounds when your start riding a lot lol.
Are you doing woods or MX?
To guy thats 180lb using 4.7 rear im assuming is a woods rider.
I have a 4.6 or 4.7 and im 155lbs
Here is what MX-Tech recommends for motocross rider at 195lbs, I put it at 195 because of gear you would be wearing. You should be fine with the stock spring rates.
Stock Spring Rates:
Fork: 0.44kgmm
Shock: 5.1kgmm
Recommended Spring Rates:
Fork: 0.44 kg/mm
Shock: 5.2 kg/mm
