Curling clutch/brake levers ??
Has anyone tried adding some curl to a stock clutch or brake lever?
I have cut mine down to about a three finger length, but I wish they had a little curl do them.
I don't know if should add some heat to bend aluminum I'm afraid they will just crack. Anyone ??
I've done this to every set I ever had. I like a 2 finger clutch. I wrap a rag around it and put it in a vice and put a little curve right before the point I will cut it off. I wack it with a rubber dead blow. Then cut it off and smooth the end. Never broken one but I don't bend it much.
If you want to be sure not to crack the aluminum, apply some heat. For some reason, they bend nicely in a fall, but they'll always break when you try to bend them intentionally.
If the lever is forged rather than cast, you'll have a better chance of bending it without it breaking. Still, a little heat in the spot you want the bend will help. Don't overdo the heat. Aluminum doesn't give much warning before it melts.
I was given a tip on another forum about bending levers. I was told to get the right amount of heat into the lever w/o melting it was to give the lever a nice coating of soot then burn it off and do the bending gently and quickly as possible
I'm going to try it with a little love from a propane torch, I think I'll start with brake lever, just in case I snap it I can still go riding....:)
coating of soot????
What is soot?
We are both from Mass. but I dont know what soot is.a
coating of soot????
What is soot?
Soot: the black gnar gnar that results from carbon deposits (i guess?) that are given off near the top of a flame. leaves a dense powdery residue. Fairly easy to wipe off.
If i was webster, that is what is how i'd define soot.
I'm from Maine and we call it soot, never really heard anybody call it anything different
