Jetting an XR100 (Pilot jet)
I'm new to this, please have some patience.
I'm re-jetting a 99 XR100 for a pipe and filter. I've bought a 102 and 105 main from jetsrus.com and swapped in the 105 with no issues.
I'm also changing the pilot from 38 to 40, which I also bought from jetsrus.com.
The pilot I removed has a longer base than the replacement I received. The threads and tip are the same lengths for both. From this I assume the 40 should effectively 'seat' in the same position as the stock 38.
However, the base of the new 40 jet does not extend as far into the bowl- is this a problem?
Hope I've made sense, and thanks in advance for any help.
Morgan
