first Bottom end rebuild
i recently bought a 1999 Rm 250 and i think im gonna start buying parts to rebuild the bottom end. I have the ability to do it (im mechanically inclined) along with the manual of course. im gonna send out the cylinder out to millenium technologies to be replated along with a new top end. so basically i want a brand new motor. i will be buying all of the necessary tools to do the bottom. but i was wondering if anybody could help me out on a parts list for the bottom.
I got this when I did mine, also I bought more than you probably need :)
new crank bearings
moose complete gasket set + oil seals
new hot rods connecting rod kit
new power valve governor assembly
new water pump assembly
new clutch basket + plates
every bearing in the engine
new transmission counter shaft
checked the shift forks, drum, and gears
new piston and rings
clean the power valve assembly
That's about all I can remember
good luck with your rebuild will u post a video or pictures once shes running? i was going to do the bottom on my rm 125 but sent it off for repair instead:)
yeah im going to be taking alot of pictures to help with the assembly but it probably wont take place until late summer......im just buying the parts slowly as money allows until i have all of the parts (and some extra money incase i find any suprises)
