3 suspension questions in one
First, I bought a new all balls seal head for my showa shock and it is set-up like a kayaba with no place for the top out spring. Did they send me the wrong one or is that their set-up? If so, is it safe to use?
Second, when I replaced my cartrige seal I saw a spring inside the cartrige. Is this a top out spring for the forks or what is it for?
Third, I noticed a bushing under the cartrige seal. Is it replaceable?
All Balls seal heads come with no topout spring (Showa, WP). You can use it, although i prefer having it.
yes, it's the topout for the rod.
With OC forks it's attached right below the rebound holder, with TC/CC forks it's located at the end of the cartridge.
yes
Thanks for the reply. When I called fc to order the cartrige seal, I asked if there was a bushing under the seal and they told me no.
sorry, i might have given you a misleading answer.
At the cartridge seal (the blue one) there's no bushing, just a metal 'washer'
at the floating psiton seal, there's a bushing.
yea, I was talking about the blue one. It looked like there was a bushing behind the seal but I wasn't sure.
ok, time for confusion :)
after, behind, ...
here are some pics. maybe you're talking about the bushing (see arrow) or the 'washer' (last pic)
the pic with the arrow is the one I am talking about. Looks like it is rmovable, but when I stick my fingure in it it wont move.
never removed it or had to so at least i don't know, sorry.
looks like you have to press it out, is yours worn?
well, the rod had alot of side to side play in it. I replaced the seal and the piston ring and it tightened up alot, but there is still some play in it. So, I was trying to find out if there is a bushing in the assembly that houses the seal that will help with this. I also noticed that there is about a 4 inch long spot at the top of the rod where the coating was worn off. Im thinking the fork has been in a bind for sometime.
sounds like a good diagnosis.
heck, when i searched my drawers for some parts i found bushings from FC, part # SMSB 1210
ID = 12mm, Length = 10mm
i'd say this is the bushing you'd need.
But you can give FC a call to make sure
Maybe they thought I was talking about the floating piston sence I ordered seals for that too. What gets me is, when I called, the guy that awnsered the phone kept having to go ask someone else to get an awnser to every question I asked. So either the guy didn't know anything about suspension and was only there to sell there jewlry or they don't allow him to do anything without asking.:thumbsup: I will have to call again. Maybe I will get someone else.
