Hot Cams Stage 2 question
Well, I'm buying the last parts for a total top end rebuild for my 2004 RMZ 250. I'm looking at new intake/exhaust cams for the bike. I see Hot Cams makes a stage 2 kit for my bike. The description though says it works with stock springs and valves. My bike will be all Kibblewhite springs and valves. Is it still safe to use the Hot Cams Stage 2 or do I have to get something else like the Stage One where the description says nothing about stock valves and springs? Thanks for the help guys!!!! :)
The only reason its saying that is most likely so people knoe that they dont need other head work before installing the cams. It wouldnt make any sense that you can use a stage one with aftermarket springs but you need stock springs for the stage two
That makes a lot of sense. I'm going to go ahead and order the set! Thanks!
I have a full set of Stage 1 that will fit your bike I order the wrong year they are brand new and will let them go for $120ea.
