new mrd pipe tire rub???
I had this issue with my Yosh. My fix was a few washers to space it and move it over to the right a little bit more. I'm assuming the MRD mounts the same way, hope this helps......:)
:) if you havent already you can check to make sure the wheel is straight in the swingarm , some times the marks are off , you can put it on a stand or have someone hold the bike up while you stand back and look down the length of the chain coming off the sprocket , if the chain is straight its good and you can shim the muffler over a little like stated in the post above :banghead:
