04 RM 250 engine compression..
What would be the average engine compression on a 04 RM 250.. Recently bought this used bike, I have the fuel tank off so I thought I would do a compression test.. I was told the piston was changed and only has approx. 10 hours on it. Here's hoping for good results.. thanks in advance..
Steve.
So I just did the compression test and with 6 solid pumps of the kick starter the tester shows 170 psi..reran the compression test 2 more times just to be sure.. right around the 170 mark.. this I believe to be pretty good, also this compression test was done on a cold motor, 38 deg.f in my shop right now...This makes me happy :banghead: not the weather by the way, :) ground still frozen in these parts, no riding yet.
That's good compression. However, as a rule of thumb it's a good idea to replace the top end on any "new to you" 2T. It's a $100 insurance policy and you also get to see what is or has gone on inside the motor.
Cheers!
