Fuel in crankcase
Engine would not turn over, was locked up, even put it in 5th gear and tried to roll it. Assumed the rings/piston may had seized. Pulled the generator cover cap in prep. of pulling clinder and a geyser of fuel/oil came from the crankcase. Pulled the cylinder/piston/rings, everything looks ok, next removed carb/tore down everything looks ok (going to rejet while i'm in there) Have not checked the fuel tank -fuel/vapor separator yet. Has anyone else had this problem/ any suggestion what else to check.
Lots of people with the same problem.Including me . Do a search for (petcock ) and you will get lots of info.
