yz125 forks
I kept searching and found out that they are 46mm. Could I take yz125 clamps and bolt them on with some spacers?
They will not bolt on with some spacers,you will need to do all the same steps you would do to put CR125/250 forks on. Your going to need triple clamps,brake system,wheel and axle.
The 46mm KYB's are the same forks on the vintage (2004 +/-) of CR125R's that were done in the recent fork swap utilizing the Emig Racing stem. Of course Yamaha and Honda have different valving specs, etc.
The Emig stem will likely press into the triples from the 97' YZ also, but as stated before, you wil need the front wheel, brakes, etc.
Good luck...
85 forks are really to small for the 230 you should have gotten the yz125 forks. This kind of change wont be easy do a little research under the username "ebeck" read everthing he has posted in the forum. before you try to take on this project. All forks will nedd wheel spacers...ETC so yea
