Jetting Database
Guys, because of a member ban the jetting database has been removed. Let's start a new one to get this great information created into a sticky for everyone's benefit. Please stick to the information below.
Year:
Elevation:
Temperature Range:
Smog (AIS):
Airbox Modified Top:
Airbox Modified Sides:
Backfire Screen:
Air Filter:
Pilot Jet:
Main Jet:
Needle:
Needle Clip Position:
Fuel Screw Type:
Fuel Screw Setting:
AP Modified:
Leak Jet:
AP Cover:
Exhaust Type:
Exhaust Modified:
Pink Wire Modified:
Year: 2007
Elevation: 3600
Temperature Range: 30-100 degrees
Smog (AIS): JB weld mod block (removed)
Airbox Modified Top: yes snorkel removed
Airbox Modified Sides: cut
Backfire Screen: stock
Air Filter: stock
Pilot Jet: stock
Main Jet: 170
Needle: JD jetting red
Needle Clip Position: 4th
Fuel Screw Type: stock
Fuel Screw Setting: stock
AP Modified: no
Leak Jet: stock
AP Cover: stock
Exhaust Type: MRD full
Exhaust Modified: no
Pink Wire Modified: no
Year: 2006
Elevation: 0-3500
Temperature Range: 35-100
Smog (AIS): Removed, Block Off Kit
Airbox Modified Top: Drilled large holes, Snorkel removed
Airbox Modified Sides: Cut, left and right
Backfire Screen: still there
Air Filter: OEM
Pilot Jet: Stock
Main Jet: 165
Needle: JD Red
Needle Clip Position: 3rd
Fuel Screw Type: RD Flex
Fuel Screw Setting: about 2 turns
AP Modified: none
Leak Jet: stock
AP Cover: stock
Exhaust Type: FMF Q4, Stock Header
Exhaust Modified: No
Pink Wire Modified: No
Year: 2007
Elevation:sea level
Temperature Range:40-120
Smog (AIS):Block off kit
Airbox Modified Top:Yes
Airbox Modified Sides:Yes
Backfire Screen:Still intact
Air Filter:UNI
Pilot Jet:Stock
Main Jet:172
Needle:NCVS
Needle Clip Position:3rd
Fuel Screw Type:
Fuel Screw Setting:2
AP Modified:No need
Leak Jet:stock
AP Cover:Stock
Exhaust Type:Full MRD
Exhaust Modified:
Pink Wire Modified:No
Perfect post to get it started again. Here's the template;
Year: ...
Elevation: ...
Temperature Range (°F): ...
Smog (AIS): ...
Airbox Modified Top: ...
Airbox Modified Sides: ...
Backfire Screen: ...
Air Filter: ...
Pilot Jet: ...
Main Jet: ...
Needle: ...
Needle Clip Position from top: ...
Fuel Screw Type: ...
Fuel Screw Setting: ...
AP Modified: ...
Leak Jet: ...
AP Cover: ...
Exhaust Type: ...
Exhaust Modified: ...
Pink Wire Modified: ...
Year: ...
Elevation: ...
Smog (AIS): ...
Air Filter: ...
Pilot Jet: ...
Main Jet: ...
Needle: ...
AP Modified: ...
Leak Jet: ...
AP Cover: ...
Exhaust Type: ...
same template in the first post?
Yup. ... :thumbsup:
I hit 'submit' before I populated template with the 'examples'. :usa: Oh well... I'm sure everyone gets the idea.
... that was a huge database too. I wonder if C-Hauler can see the "deleted" thread (as a MOD). If so, he can merge it with this one, and we'd have it back again.
Year: ...2005 450X
Elevation: ...sea level -9000 ft
Temperature Range (°F): ...30s-105f
Smog (AIS): ...applied / "scoots" JB mod
Airbox Modified Top: ...Fully Hacked
Airbox Modified Sides: ...Fully Hacked
Backfire Screen: ...Removed/stock cage
Air Filter: ...Twin Air power flow
Pilot Jet: ...48
Main Jet: ...172
Needle: ...JD red
Needle Clip Position from top: ...4th clip
Fuel Screw Type: ...CRF's t-handle
Fuel Screw Setting: ...2 turns out
AP Modified: ...Wired
Leak Jet: ...Stock
AP Cover: ...Stock
Exhaust Type: ...FMF Titanium Powercore/Stainless Powerbomb header
Exhaust Modified: ...Stock exhaust is
Pink Wire Modified: ...Yes
:thumbsup:
Year: 2007
Elevation: 1000 ft
Temperature Range: 50-100 deg
Smog (AIS): Removed
Airbox Modified Top: no
Airbox Modified Sides: no
Backfire Screen: intact
Air Filter: stock
Pilot Jet: stock#42
Main Jet: 158
Needle: NCVS
Fuel Screw Setting: 1/2 turn out from factory setting
AP Modified: no
Leak Jet: #60
AP Cover: stock
Exhaust Type: stock
Pink wire modified: no
Year: 2005 ( # 141)
Elevation: 0-3200
Temperature Range: 45 - 120
Smog (AIS): BLOCKED (KIT)
Airbox Modified Top: FULLY OPENED TOP
Airbox Modified Sides: OPEN RT SIDE ONLY
Backfire Screen: REMOVED
Air Filter: UNI RED
Pilot Jet:48
Main Jet:170
Needle: JD RED
Needle Clip Position: 3RD
Fuel Screw Type: ZIP TY
Fuel Screw Setting: 1.5-1.75
AP Modified: R&D POWER PUMP KIT, (NOT THE AP BOWL, JUST INTERNALS), AP TUNING: 1.1 SECONDS, UNDER SLIDE
Leak Jet: 45
AP Cover: STOCK
Exhaust Type: DR D FULL STAINLESS (2006 VERSION)
Exhaust Modified: AS ABOVE
Pink Wire Modified: YES, RADICALLY MODIFIED WITH MOLECULAR ENHANCERS
Year: ...O7
Elevation: ...5000'-12,000'
Temperature Range (°F): ...30-100
Smog (AIS): ...BLOCKED
Airbox Modified Top: ...YES
Airbox Modified Sides: ...YES
Backfire Screen: ...GONE
Air Filter: ...TWIN AIR
Pilot Jet: ...42
Main Jet: ...165
Needle: ...JD RED
Needle Clip Position from top: ...4TH
Fuel Screw Type: ...ADJUSTABLE FLEX
Fuel Screw Setting: ...2-2 1/2
AP Modified: ...NO
Leak Jet: ...55 I THINK?
AP Cover: ...STOCK
Exhaust Type: ... FMF POWERBOMB HEADER, '06R MUFFLER
Pink Wire Modified: ...NO
Year: ...05
Elevation: ...-20 to 8000
Temperature Range (°F): ...40-120
Smog (AIS): ...49 State Model N/A
Airbox Modified Top: ...Si
Airbox Modified Sides: ...Si
Backfire Screen: ...Si (mandatory)
Air Filter: ...OEM/TwinAir/NoToil
Pilot Jet: ...48
Main Jet: ...180
Needle: ...JD red
Needle Clip Position from top: ...3rd
Fuel Screw Type: ...Stealth SS
Fuel Screw Setting: ...-2
AP Modified: ...No (only timing)
Leak Jet: ...78
AP Cover: ...Stealth Billet
Exhaust Type: ...MRD Header/Stock R Muffler
Exhaust Modified: ...PMB sparky
Pink Wire Modified: ...Si (waste of time)
Year:2006
Elevation:-20 to 8000'
Temperature Range:0-100
Smog (AIS):not equipped
Airbox Modified Top:yep, all removed along the mold line.
Airbox Modified Sides:yep
Backfire Screen:yep
Air Filter:factory
Pilot Jet:42
Main Jet:168
Needle:'06 R needle Honda pn#16202-MEN-671 (big improvement over factory)
Needle Clip Position:2
Fuel Screw Type:ZipTye
Fuel Screw Setting:about 1 3/8 to 1.5
AP Modified:no
Leak Jet:65
AP Cover:nope
Exhaust Type:'05 R header
Exhaust Modified:Factory muffler w/o plug
Pink Wire Modified:yep
Plus:
'02 450R cam
Link to 'The Wrench'
Year: 2006
Elevation: 500-6000+
Temperature Range: 40-100
Smog (AIS): removed
Airbox Modified Top: fully opened
Airbox Modified Sides: yes
Backfire Screen: removed
Air Filter: stock or twin air
Pilot Jet: stock(45)
Main Jet: 170
Needle: NCYS
Fuel Screw Type: R&D
Fuel Screw Setting: 2 turns out
AP Modified: thick o-ring(JD jetting)
Leak Jet: stock(65)
AP Cover: stock
Exhaust Type: Yoshimura TRC carbon system
Exhaust Modified:
Pink Wire Modified:NO
Year: 2007
Elevation: 61 metres (200 ft)
Temperature Range: -5 to 25 centigrade
Smog (AIS): N/A
Airbox Modified Top: No
Airbox Modified Sides: 8 x 20mm holes drilled
Backfire Screen: In
Air Filter: Std
Pilot Jet: Std
Main Jet: 162
Needle: Std
Needle Clip Position: Middle
Fuel Screw Type: Std
Fuel Screw Setting: Std
AP Modified: No
Leo Vince exhaust fitted
Exhaust header is standard
14/42 gearing on 17" road wheels
Year: ...05
Elevation: ...7000-11000
Temperature Range (°F): ...45F-80F
Smog (AIS): ...NA
Airbox Modified Top: ...no
Airbox Modified Sides: ...Yes
Backfire Screen: ...Gone
Pilot Jet: ...48
Main Jet: ...165
Needle: ...JD red
Fuel Screw Type: ...CRFs only
Fuel Screw Setting: ...1.2
AP Modified: ...Small O-ring
Leak Jet: ...Stock
AP Cover: ...Stock
Exhaust Type: ...Stock
Exhaust Modified: ...NO
Year: ...2006
Elevation: ...4000-10000
Temperature Range (°F): ...60-95
Smog (AIS): ...none
Airbox Modified Top: ...Yes
Airbox Modified Sides: ...No
Backfire Screen: ...Stock
Air Filter: ...Notoil
Pilot Jet: ...42
Main Jet: ...165
Needle: ...Stock
Fuel Screw Type: ...Stock
AP Modified: ...Yes
Leak Jet: ...Stock
AP Cover: ...Can't remember
Exhaust Type: ...Yoshimura slip on, Stock header
Pink Wire Modified: ...No
REVISED 4-11-2009:
Year: 2007
Elevation: 3600-10,000
Temperature Range: 30-120 degrees
Air Filter: stock
Pilot Jet: stock
Main Jet: 170
Fuel Screw Type: R&D Flex Fuel Screw
Fuel Screw Setting: 1.25-2 turns out
AP Modified: no
Leak Jet: stock
AP Cover: stock
Year: ...'05
Elevation: ...2000-9500
Temperature Range (°F): ...20-115
Smog (AIS): ...N/A
Airbox Modified Top: ...Cut
Airbox Modified Sides: ...Right side drilled
Backfire Screen: ...On a Shelf
Air Filter: ...Stock
Pilot Jet: ...45
Main Jet: ...165
Needle: ...JD Red
Fuel Screw Type: ...Fancy Red One
AP Modified: ...Fat ring (jd)/ timing adjusted
Leak Jet: ...45
AP Cover: ...stock
Exhaust Type: ...LeoVince can
Pink Wire Modified: ... Yup 10hp
15 tooth up front
Year: 2005
Elevation: 4000
Temperature Range (°F): 20-110
Smog (AIS): n/a
Airbox Modified Top: YES
Airbox Modified Sides: YES
Backfire Screen: GONE
Air Filter: OEM
Pilot Jet: 42
Main Jet: 170
Needle: JD Red
Needle Clip Position from top: 4th
Fuel Screw Type: oem
Fuel Screw Setting: 2.5
AP Modified: NO
Leak Jet: stock
AP Cover: stock
Exhaust Type: 2005 CRF450R Muffler
Exhaust Modified: 2005 CRF450R Muffler
Pink Wire Modified: NO
