06 stock jetting??
any one got stock 06 jetting specs? main, pilot and clip position??
the delemah im having is sit at idel, blap the throttle and idel goes verry high for aroiund 5 seconds then drops back
jetting is as follows main 178, pilot 42 and clip position 2nd from top
i couldnt find any stock jetting spec's on google. u could try calling a local kawi shop and ask? whatever your problem it is making u run lean.
First Q. is there any air leaking anyway?(check the boots around the carb and air box.)
Second Q. is the carb clean?
Third Q. whats your spark plug look like?
I just got my carb back from TokyoMods and its awesome(06 kx250f). bike now idles fine and no bog off idle. Much more responsive everywhere in the powerband. o ya and no more popping! i got lazy and didnt want to mess with jetting my 4-stroke. to much crap in the way!
plug looks good mate, no air leaking, and yeh pulled all jets out etc and gave em a clean up.
stock jetting is 40 pilot 180 main and 2nd clip from top apparently and 2 1/8 turns out on the pilot screw, ive half fixed the problem wich im alot happier with it doesnt idel at 5k for that period any more prob just about 2k i put the clip to the 3rd grove down from top and used a 42 pilot 178 main and pilot screw at 2.5 turns out.
i dont think i helped much, but glad u got u running good now!:thumbsup:
