fuel screwed?
I noticed my fuel screw was 3.5 turns out while I was taking my carb apart to clean the pilot jet. I've been having a problem with my bike not idling without the choke. Could this be my problem?
More than likely not, not running w/o the choke is a sign of a plugged PJ. I would reset the fuel screw to 3 turns out and keep an eye on it.
Assuming the screw was less then 3.5 turns out this would be the problem.
Turning the screw out and choking have the same effect.
Alltough choking has a bigger effect then 1 turn or so.
What was the previous screw setting?
If unknown: 3.5 turns might have been where it has been all the time.
Did it run wel before?
Id look into the pilot jet.
I pulled the pilot jet and it wasn't clogged, unless there is something clogged deeper in the carb.
What size pilot? Was it shiny brass colored or dark?
  • Similar Content
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
