Hard to start w/o choke
Hi all,
All the bikes I've owned except my current KX250 would start fine without the choke after the initial start up of the day. Half of the time with my KX250 though, if I shut it off even for a couple of minutes, I end up needing the choke to start it back up. I don't think it's a matter of being too lean in the pilot because it did this even when I was a couple of sizes too rich on the pilot. The bike runs/idles fine. Any ideas?
Maybe one size too small pilot jet. I make mine like that though because I like a clean of idle and that happens sometimes.
Ed
Thanks guys.
Yes, I did verify the pilot jet size. I know it sounds like a lean pilot, but it acted like this even when I had a couple sizes bigger pilot installed.
Well that's not it either. The top end only has 4 rides on it right now.:p
pull out your plug before you start it, mine used to do the same thing. This will give you a idea if you need fuel or need to lean it out
Mine was too rich.
Do you have a small intake vacuum leak? That can sure make 'em hard to start or require using the choke on a warm motor.
Take your bike OUTSIDE. With it idling, spray a little starting fluid (ether) around the intake boot ends. If the idle speeds up, you got a leak on the end you were spraying.
I will try that next time I fire it up, thanks!
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
