Question abouy 07 yz250f clutch problem.
I just got a 07 yz250f and i went riding the other day and everything was great. Then after washing the bike and driving home i noticed a problem. When the bike is in gear with the clutch pulled in its is ver hard to roll forward or backwards. The cable works fine from what i can see. Just need some help any ideas on what it could be and what i should do to fix it? Thanks in advance for any help.
a cold engine will make the bike feel like there is alot of drag....as long as you can push it your ok....the worst case is if the bike is running and with the clutch properly adjusted it creeps and is hard to get neutral...then you have a clutch problem..
