Help CRF 50 Wont Start
I just had a quick question I was hoping to get some help on. I have a 04 CRF 50 that i cant get running for the life of me.
I bought it and it ran fine, but after i had it for a while and put a UNI clamp on it never would idle right. it would just die no matter how high you set the idle. you would think you had it, and then it would just die.
I have cleaned the carb and the gas is new. the plug is an NGK and is new.
Now i can barly get it to start. when it does it revs up and then just dies. if you try and give it gas, it bogs. i have tried everything. the plug is a sooty black when i pull it out leading me to think it is running to rich, but even with it right, it should idle.
please help. any ideas?:p
is your uni filter clean ? I have had weird problems with the air filter dirty. Try starting it without filter on
IF you went from a stock filter to an aftermarket filter, you might need to jet it richer..
Have you tried using the choke to start it?
Also check your valve adjustment.. I check mine every couple months since it literally takes 5 minutes..
If I don't adjust mine for 6 months then my bike doesn't want to ever idle right
edit: ahh missed the part where you said the plug is black..
Try it with no air filter and see what happens like BlingBling5O said
i have tried it wiht no filter on it. how do you adjust the valves? im new to 4 strokes.
Check to make sure the ground strap near the airfilter is secure being that you removed it to take off the airbox and check the valves [do a search on valve adjustment]
the ground is good. it has spark when i kick it over all the time. i also tried a jet cleaning set at my local shop and not even the smalled bit would make it threw the pilot jet. ill try wtih the valves. who has a stock carb they want to sell me?
PM sent:~)
  • Similar Content
    • By RCWSO
      I have an 07 CRF70 that I have done the filter pod modificaiton by cutting the extension tube off and I have drilled a couple of holes in the end of the exaust per some instructions on a thread here at TT.
      I have recently had some problems getting the bike to idle consistently. I am wondering if I should try and rejet the bike at all or get a needle from an older carb that is adjustable. I do have a unifilter that I can put in as well with the stock pod that I cut.
      It is not that the bike wont run or start, it just seems to only idle if I turn it up significantly but as soon as I turn it down even 1/8 of a turn it dies. But the idle that I set to keep it running well is too fast as the bike will move forward if in gear and no throttle is applied.
      Any suggestions? Jetting, needle, air screw change with an older carb?
    • By the-new-kid
      hello guys I'm like really new to this, like extremely new but I was going to buy xr-70r from a friend and drop a Lifan 125cc engine in it (here's the link: ). Now the site says its a 4preed trans with normal gear set up (1-n-2-3-4), and manual front clutch, I'm wondering if I need to buy the clutch lever, perch, and cable then connect it all. Then secondly, what pip should I be looking for I'm not sure if the header would have to be a different style or what exactly.... please be patient with me I'm doing the best I can to learn... thanks
    • By anger806
      hi im new to the forum and i am running a stock 2005 crf 50f with pro tapers but no engine mods what size carburetor should i be looking for to get a little more pep out of my motor?
    • By HondaRacer37
      Hey everyone.  Darn glad to have found this forum!
      Just bought my son a 2009 CFR70 (first bike - 8 years old) and the first thing I'm doing is scrapping the factory air box for a UNI pod filter.
      I'm looking for advice on how I can open up/modify the factory exhaust for more performance.  I heard about removing the screen and drilling some holes but have not found those posts. Any specific advice would be greatly appreciated. (Found only a couple performance aftermarket pipes that were very pricey.)
      I'm thinking after the air filter change and pipe opening the main jet size may need to be increased. It's a stock 13mm Keihin carb.  What size is recommended?  Haven't looked at the stock size yet.
      I assume the needle is adjustable on the slide (but don't know if this would do any good or be necessary anyway) and hope there is an air mixture screw somewhere because it seems the carb could use a bit of adjustment now.  Although next to the idle screw it looks like a brass cap or plug rather than a screw. (See photo attached.)
      Thanks for any advice.  It's great to be part of this group.  Ride on!
      Greg in Florida
    • By thousandbuckle
      Hello all, reaching out to you today to get some help with a small project I am trying to do.
      I just bought a 2006 CRF50 for my 3 year old and would like to rig it up with a wireless remote kill switch for those just in case moments. I have the throttle speed screw installed and will limit it that way also but want a back up until she is proficient and I feel confident.
      Since this bike does not have electric start there is no battery. I was wondering if any one has or knows how to rig up a wireless car alarm system to work as a remote kill switch. I know I will need a 12 Volt battery on the bike which I can get. I know there is a product from 3Built that does this but the range is only 250 feet and some say it is even less than that. I was thinking of a car system since the range is usually around 1,000 feet which is overkill but I prefer overkill when it comes to this topic,
      Any DIY thoughts you might have or suggestions would be appreciated.
