[[Template core/global/plugins/realFaviconGenerator does not exist. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] Jump to content
Top end rebuild
I notice your piston is a lot more "scruffed" up then mine was when I did mine a couple of months ago....unless I'm just seeing "blurry".
Yes it was scruffed up but not as bad as it look's in the photo.
Ill show what was bad the boysen reeds.
The ok side
And the bad side
ooh...no sh*t. I just went to replace my stock reeds with some boyeson reeds I bought on saturday but when I got in there mine looked like brand new so I didnt change them. From what I've been reading the boyesons are good if you change them with every top end, but I've read some posts that said they lasted only a very short period of time in some cases, so I left the stock ones in. How did the cylinder look?
I thought the cylinder looked ok but then i seen this
This is getting rechromed now.
See just above the export it has been niped.
Yeah, I see the marks...pop back in and post a pic and a final bill when you get it back please.
Ok all I'm upto the final stage of my rebuild but i have ran into a big wall lol. Ok if you look at the top of my piston chamber you will see 2 rubber orings i think that is the VHM head gasket. Now if I'm right i have a big problem because i cant get a VHM gasket any where now i think i can reuse the old would some one recommend that or should i try and use the copper gasket that came with the top end kit any ides on what i should do.
That engine doesn't use a copper gasket, it uses o-rings. OEM or aftermarket will work equally well. If you bought a Cometic kit with the piston kit it should have the correct o-rings in it.
