transmission problem
Hey all, I'm looking for a little advice here. While draining my trans oil on my 07 crf450, I pulled my shift lever up in order to wipe up some spillage. Now my bike will not come out of gear. The shift lever moves freely up, but not down. It's stuck in first. clutch is properly adjusted and I have had no problems previously. I drained the oil so I could replace my water pump seals as I had a pretty bad leak. Any ideas on where to start would be great. thanks for anything.
the simplest thing i would try is moving the bike forward and backward physicaly for few meters and try to push the lever down while doing that. i had the same problem and it worked.
i hope it works for you too!
