Is this normal? Oil level question?
Ok I just finished and oil change on my drz400s. I put in 2 quarts, start it and let it run for a few minutes. I checked for leaks and didn't see any so I thought it was all good. The next day I came out and checked the oil and there is not a drop on the stick, and there are no puddles under it. After thinking about it I had an older dr350 that was the same way.You can start it and warm it up then let it sit for a minute and check the oil and it looks fine but if you try to check it when its cold and been sitting over night it looks like it don't have a drop in it.
So I am just wondering is this normal? Did I do something wrong with the oil change? I changed the oil and filter and 2 quarts should have been more than enough. And yes I tried checking it leaning on the kickstand, standing up straight, and leaning to the right a little and all three times is shows no oil. So whats the deal?
thanks for any comments
If you ran the bike , then shut it off and waited till the next day to check your not gonna see anything. it's run three minutes, off three minutes then check
The Suzuki Manual says run for 3 minutes and shut off for 3 minutes and check. Some bikes require more time for this check. If you put 2 qts in, you are good.
If you check it cold it will always have a bone dry dip stick. You MUST run the bike for a few first.
http://www.thumpertalk.com/forum/showthread.php?t=769901&highlight=oil+level
+1
Exactly, it's a dry sump, so if you look in the manual, after sitting the oil will fall into to bottom, you need to let it run for a few min, let the oil warm up and run thru-out the motor, then wait 3 min, then CHECK the level.
also when checking you oil level hold your bike upright.
I find the 3min x 3min rule doesn't always work. If you put two qts in it and it hasn't leaked, your good! Ride it!
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
