Oil on ignition side
I recently pulled off the cap to turn the crank so i could put the engine on tdc to inspect the valves.
When i removed the cap to turn the crank oil came out. Is that normal? I thought that side of the engine was meant to be dry.
Is a seal damaged in my engine somewhere?
Think i had a brain fart and it only came out because my bike was on the side stand. Not to worry.
She aint no 2 stroke. The flywheel is in a slight oil bath too..
