Carb Capatibility Question
Will a stock BSR carb from a 2006 DRZ400 SM fit a 2004 KLX400?
Yup, it will
stock carb on the SR model.
the R model will need throttle cables & inlet & outlet boots & clamps from the SR model to adapt.
What's the SR model?
The Kawasaki KLX-400 came in two versions:
The KLX-400R, the off-road-only bike.
The KLX-400SR, the street-legal dual-purpose bike.
These bikes are just rebadged Suzuki DR-Z400 models.
The DR-Z400 also came in the off-road-only and dual-purpose versions:
DR-Z400E, off-road
DR-Z400S, dual-purpose
So:
KLX-400R = DR-Z400E
KLX-400SR = DR-Z400S
DR-Z400E, off-road
So:
KLX-400R = DR-Z400E
Thanks. I was familiar with the DRZ model types, but not the KLX, which is kinda funny because that's what I have. I have the off-road only model with a street legal kit, so it looks like I'll need the boots, clamps, and throttle cable. By the way is there a way to mark these threads as [solved] ?
What is wrong with the FCR on your bike? It is the better of the two as long as it works.
Multiple problems actually. I have written about it on another thread I created while diagnosing problems starting my bike, you can search for it. Basically, one of the mounts for a float bowl screw is stripped, and idle screw is broken (both the cable and the part where it screws in), and it keeps getting stuck an not letting gas through it, even though I cleaned it out. I think I can get the BSR36 cheap, so I might buy it to at least hold me over until I can purchase the fcr-mx.
Ah, ok. I missed that. Sorry.
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
