Rekluse?? Hinson Slipper clutch?
Ive been hearing about these different types of clutches for a while and never really understood what the rekluse really does. Also with a hinson slipper clutch what are the benefits and are both these different clutch types worth the money? Thanks
Tommy
Rekluse is an automatic clutch that can also be used manually. Typically for extreme single track.
A slipper clutch 'slips' when off the gas, keeping the rear tire from skidding on hard downshifts. For pavement
If you do not know what the are, have situations where you say "Man, if only the clutch was automatic" or "Damba, I am, killin' my rear tire through those corners." then you do not need them.
