drz facelift
I have been driving my drz400s for a couple of yers now. After this winter i descided to do something about it because it didn´t look to good. It´s a -00 and has had some tough moments in the woods. This is what the bike looked like when I started the surgery.
After about 40minutes with my Bosch screwdriver the bike looked like this.
I decided to paint the frame in blue.
Regreas and replace...
And then the engine...
note the blue cap on the left side of the engine.:p
A day later the drz started to look like a bike again. Now with sm-wheels.
Subframe
I decided to remove the oem airbox so I had to use a old frontfender as a rearfender.
Tank and some more fenders
I painted the exhaustpipe with "hotpaint"
Almost done
I like blue:worthy: The airfilter is made to fit cars
Like a glove
Some say the blue frame on a suzuki is oldschool, some call it husaberg-wannabe. Left to do is numberplate-mod and fit a speedometer
the blue frame looks good:thumbsup:
back in the early 80's i always did my rm frames in blue to look like the newer bikes of the day.
and.....stop your bragiing about how fast your project is coming along:busted:
i can't seem to find time to finish mine. i spent sooo much time prepping the frame for paint.
edit....my plastics looked worse than yours. they cleaned up pretty good in the kitchen sink with a kitchen scotch bright pad & some baking soda.
I'd recognize that PJ1 Suzuki Blue Epoxy paint anywhere.
Nice Job.
Damn man! Nice work! Love the spray booth you made and good choice on the old school blue/yellow suzuki look. Welcome to the world of SM! :p
How does it run with the new filter? I like the Blue, I am just doing mine and was thinking of a slightly darker blue for frame forks and swingarm. That blue goes well with the yellow plastics.
This was a low budget project:
-Blue paint
-Hotpaint for the exhaust
-Grease, fork oil, engine oil etc
-Airfilter
-Some blue hoses
-Hoses for the connection between carburetor and airfilter (from the junkyard)
-Sprockets and chain
At first I wanted to paint the frame in aluminum-gray and have black plastics and tank. But when I opened the gray can it looked more like white. So I decided to go for the old school look. But wasn´t the rm:s more dark blue?
The engine runs well. But I will tune the carburetor som more.
Very good work man, the filter is "sick" but isn't suggested by Eddie. I noticed two details :
1) Blue toolbox and blue bikelift, i hope that the paint is over before you'd paint everything in blue!!! :p
2) The serious detail is your cam chain tensioner:jawdrop: , i can't believe that it stiil works. You should replace it with an aftermarket Manual CCT or an OEM ACCT of newer DRZ.
Nice rebuild, looks good especially with the naked air filter view.
1) Blue toolbox and blue bikelift, i hope that the paint is over before you'd paint everything in blue!!! :cry:
1) The toolbox, the bikelift and the paint are actually bought in the same store.:lol: As well as the airfilter.
2) The cam chain tensioner is working just fine. It´s home made like everything else on my vehicles. :p
I like the painted frame. Just curious, while you had everything disassembled, why didn't you paint the subframe to match?
Looks nice. Need some new plastics now.
i would guess because paint doesn't adhere to aluminum well.
I think it looks better when the subframe, stering head and swingarm is aluminum. Aluminum is more racing, that´s why I don´t paint it.
Yes, but now I just want to ride :p
  • Similar Content
    • By Caycee Justus
      I had a gsx-s750 and got rid of it and picked up a 2015 drz400sm this week. It's used and the last guy put knobbies on it. I'm switching back to Michelin power 2ct. stock tire size is 140/70. The current tires are 150/70. I was looking at running 160/60. Anyone know if this would be a problem? I'm just getting into the supermoto life so any other general suggestions would be great. Thanks!
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
