new battery, clicks but wont start
I had to put a new stator cover on my bike... I'm thinking something went wrong with the starter gear install. I have a new battery in the bike, freshly charged, all it does is click. If I take out that starter gear behind the 3 phillips screws (on the stator cover) and hit the start button, the starter turns over.
is it possible to put that starter gear asssembly in wrong? itll pop start and run fine too.
is it a really fast ticking coming from under the seat/number plate? could be a loose connection on the starter relay.....
nope its not that fast clicking noise... but im familiar with that.
its a solid click, soons you hit the starter button. If i have the starter gear cover off, you can watch the gears trying to turn the motor over but it doesnt.
You may have a shim in either the torque limiter or idler gear in the wrong place, worth revisiting.
william i went back before i read your post, took apart the side cover... realized i had a shim for the starter clutch in the wrong spot. Put it back together, she starts right up.
Kind of a waste of money to buy a new battery... but O well.
Glad you got it going. Now you have a fresh battery for the season.
  • Similar Content
    • By Supermotofool
      I totaled my DRZ400S last year, did a good bit of work to it and finally got it running.. I want to turn this into my full stunt bike.
      I have read before about people buying a 2nd stock rear caliper & bracket - then cutting and welding it to the existing bracket, then just running a handbrake master, and a hose to the 2nd caliper.
      Has anyone done this before? Defiantly seems to be the cheapest route to go (staying away from the junction valve / 1 master cyl. & 1 caliper setup.)
      Looking for opinions, pros/cons, and info if anyone has gone this route.. If it seems too much of a risk or hassle I guess im gonna have to spend the $500/$600 to get a legitimate setup
      any and all comments are appreciated - except trolls.. you better be funny as hell if your gonna troll.
      Thank you all!
       - Brad
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
