XR650R Radiator Fan - which one is this??
Hello all,
I recently picked up a used XR650R and started doing some basic maintenance.
The radiator fan looks very elaborate and expensive ... here are a couple of pictures:
I did several searches (here, the XR650R forum, advrider) and saw all the computer fans, KTM fans, and other fans ... but never saw this type.
Any idea what kind this is? Looks like it has radiator fluid going up into the unit? It has a vacuum line going to it, not sure what that is for. Seems way too complex for just a fan ... any ideas??
Thanks!
That my friend is not a fan, it is an Air Suction Valve. Look it up on your Fiche parts finder on something like oldbikebarn.com
yeah part of smog stuff right? i would look into getting rid of the smog stuff and block off
can you do this to the XRR??? How?? i guess i've read of doing it to the XRL. i think in part of "Dave's Mods??"
yeah i'm not sure if i am right or not about the Dave's carb mod, but....can this be done to teh XRR anyways??
It is really simple to remove the smog stuff.
The block off kit is just a small plate of aluminum that bolts over the exhaust ports and a rubber stopper to cover the nipple on the intake manifold.
I recommend not using the rubber plug. Go buy a stainless allen screw (m6?) and replace the brass nipple with the screw.
i see where you can do this on the XRL, but my question remains...is it possible to do this on the XRR?
possibly a more detailed explanation would be better with visual aids??
what are the benefits?:p
i guess i've never seen a write up about this being done on the XRR, thats why i'm asking.
so that's wut that thing looks like!
...they're not on R's down here...looks kinda like a "cludge" but that's wut happens when engineers are forced to add things after the fact :lol: my manual doesn't even have info on it...wus it a Cali only thing?
i believe Ryanthegreat1 wus tell'n u yes and how it can be done.
:p
Thanks guys!
Looks like XRs Only has a block off kit ... I guess others might as well.
Anyone know what this thing does? It looks like a self contained until ... two hoses running towards the front part of the cylinder and one hose that is a vacuum source. Does it pump fresh air into the exhaust or something?
Guess I need to rename this thread. :p
Hummm ... just called my local cool shop (non Honda, dirt bike parts shop) ... they recommended to just leave it on ... they said the performance doesn't change at all, so you are basically paying $25 plus tax to drop 1lb off the BRP. But maybe that isn't bad ... wish I could pay $1000 and drop 40lbs!!
:p
i'm in SD and i have one!! GET IT OFF GET IT OFF:bonk:
oh crappers i lied, i thought i had one Wheww!!
of course you can take off any smog stuff!! all mine came in a box when i bought my bike
Was it all of the 07's that had the smog? Everything before that was without unless it was a California model.
And yes I was giving directions for the XRR.
It assists in pumping crap back in to your motor so you can save
the ozone by burning more gas to overcome the crap that is being pumped
back in to your motor to save the ozone then you use more gas to overcome
the crap that is being pumped back into your motor to save the ozone…
see where I’m going with this…
this is not the crankcase breather system that reburns the crankcase vapors/emissions...
...rather it's the pulsed secondary air injection system(PAIR) that injects air into the exhaust ports to aid in burning unburnt hydrocarbons...
:p
:cry::p:lol:
:p
NOOOO its crap that should be blown up and discarded, not some silly PEAR PUMP, YOU FREAK!!! LOL :lol:
well...if anyone knows about get'n "pumped" it's Big Denn... :cry:
...dude, u better lay off the sauce *hic* or do u have sumone to drive u to Pig Fest??? :p
:lol:
P.S. make sure to give Bruce & Rich a big hug for me and throw in a grab-azz too! :lol:
Leave it on. Absolutely no performance gain at all by taking it off.. There are off-road parks around northern CA that will actually send you home if you do not have your smog pump on (Hollister Hills, Carnegie.)
Well, I think I'll leave it on ... seems kind of goofy but I have also heard of tougher checks at the offroad parks.
I looked at changing the thread title but doesn't look like I can do that ... was thinking "What is that hideous growth on my radiator where a fan should be?" or something. :p
Thanks for the info guys!
  • Similar Content
    • By Motorius
      Can anyone tell me if a Showa rear shock off an XR650R would definitely fit an XR650L (mine is a 2008)?
      Thanks!
    • By Pcolamotorhead
      Parting out almost an entire bike. Frame is gone, CDI box, and Wheels, Gas Tank, Headlight & Front number plate. Complete unassembled engine with 9611 miles on it. 90 pounds of compression at cranking speed. According to hondaprokevin.com this is what it should have.  Checked the compression with 3 different gauges.   Valve clearance is good which indicates no cam or rocker arm wear. Oil did not look too bad that came out of it. Corbin seat, Super trap muffler, and just about all the other parts.  Shoot me a message with what you are looking for and I will be happy to take pics and send them to you along with a price. All items are buyer pays the shipping.  Also have some 1996 Honda XR600R parts. Engine cases, Electronics, Etc.  $850 for the motor and you pay shipping, Starter motor not included.
    • By Jeremy Evans
      I just bought a 2012 xr650l and it starts and runs great until about 4000 rpm give or take (I’m guessing) it feels like it spits and pukes. Also when releasing the throttle the exhaust pops and hiccups. I am calling the dealership to ask if they are willing to fix the problem as I just purchased from them yesterday but I am curious as to what the problem could be in case they do not offer to help for my “as is” purchase. I have read a couple other topics on here that talk about the vacuum lines being hooked up to an air cut diaphram but I don’t know what that is. The smog delete has been done on this bike as well as a slip on dg exhaust and the side cover has a bunch of holes drilled in it exposing the air filter. The battery has also been relocated. My question is what jetting should I have at 2000 feet? I am planning on opening up the carb to see what the idle jet and main jet are and if they were even changed from stock. Also if someone knows about the air cut being hooked up to vacuum and can supply pictures that would be very helpful. I know that the smog block off kits just plug the vacuum holes and the air cut usually gets disconnected. Thanks.
