Lubing my chain
From similiar posts on here...quite a few do. However...it really is a "water displacement" agent. Not a lubricant.
I can't remember the name of the one I use...I always leave it at my friends house...:p
WD-40 is NOT Lube. It's used for penetrating. Use Klotz or other similar chain lube. :p
I have seen lots of people use it, even on non-orings. I'll use maxima chain wax, at least until I run out and switch brands again.
WD40 is better than nothing, but it's not very thick, doesn't really protect the chain for very long...
You can use WD-40, but why would you? It is not a lubricant as everyone else said. Antifreeze is more of a lubricant than WD-40, but would you use antifreeze on your chain?
What is the best way to clean o-ring chains? I usually use spray on white lithium grease is this fine to use?
