CRF 230... New exhaust vs. uncorking
2005 CRF 230. I have an opportunity to buy a like new BBR exhaust (not the D2) for $100. Will it make much difference over removing/drilling out the stock baffle? I woll rejet and modify the airbox as well. Thanks for any input.
And look cooler....:lol:
hell ya :p
Only reason I haven't got an exhaust yet is I don't wanna spend $200+ :cry:
I might pick up the $80 mid pipe though from poweroll for my 150f :lol: :lol:
I think you're advantage will be weight. As for power, it's really hard to get a lot more power out of these little bikes by just a pipe. $100 is a deal though. You have to step up and buy it!
Personally I don't feel that aftermarket exhaust systems are anything but a scam on 4 stroke bikes when power numbers are quoted. Typically your going to find your best performance range somewhere between a straight pipe of a large diameter and an exhaust system that provides some measure of back pressure.
Straight pipe = peak hp with a major loss of low end torque.
Exhaust system that is too restrictive = loss of top end but better all around low end driveability.
The area between wide open and too restrictive is extremely broad, and the power difference in that range is going to be minimal. Yes, you can tune a 4 stroke exhaust for peak hp with useable torque or peak torque with useable hp, but in the real world your actually looking for a good compromise of power and noise.
My point and my personal opinion: A stock exhaust opened up with the proper engine mods to utilize the free flowing exhaust is going to perform so close to the perfect aftermarket exhaust system as to be undetectible by anything other than a good dyno.
................. but the aftermarket exhaust systems will make your bike look cooler....... if that's what you're spending the hundreds of $$ looking to accomplish.
wow it really improved the appearance of the bike nice pipe bet it sounds great
Ok, I finally went on a REAL ride, and got it nice and dirty for you all.......
I LUV the new pipe! sounds great and really semms to run great, and these tires really do SUCK!
ha ha that looks like my bike after today all covered in mud
Hard to say. I didnt ride it much with the old one. Sure sounds alot better! It seems to really have plenty of torque and runs great. Havent done any carb/airbox mods yet but plan to in the coming week. Project right now is putting on the new tires.
CoeShow dyno'd the CRF230 back to back with uncorked stocker and BBR. The diff was half horse.
That sounds tiny - but every little bit counts - it's possible it revs quicker too - so that could be an added benefit. (?)
Mikeee
I agree. The exhaust alone on a smaller displacement bike is not going to add any significant power. Porting the head, re-jetting and opening the airbox will add power. Boring it is the ultimate way, as "there is no substitute for cubic inches" , an old hot rodder's phrase. For example: my '85 XR200 runs like a strong 250. I ported the head, re-jetted richer, opened the air box, new Uni foam filter, replaced the coil & wire, and added an iridium plug. I also added a CRF230 muffler (local cycle salvage $50), with the baffle modified (4 additional holes). Strong low end, pulls well. I am very happy with it, not bad for a 31 year old XR.
Edited by HomerDodd
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
