Light weight battery???
I saw a post maybe last week (for some reason, I can't find it). Someone found a company who makes these very light weight batteries that are basically just made out of a blue plastic wrap. They sell for about $120 or so I believe.
Anyone know what I'm talking about? I thought it'd be nice to loose some weight that's so high up on the bike.
Thanks,
Steve
I started the thread referred to in the link above and I am still undecided as to their suitability. I was hoping more people with experience using those batteries in a DRZ would chime in with how they were working, lifetime, and etc but I didn't really get a lot of feedback. If you get one let us know what you think of it on your DRZ.
It doesn't sound like many have tried it. Perhaps you can try the general forum. Perhaps they have been used by someone on a different bike.
I have looked there and corresponded with a couple people that are using them. Their bikes are typically more trail oriented bikes like KTM, WR's and such and most have a kick starter if the battery goes flat during a starting attempt while out in the boonies. I don't think many have tried it on the e start only DRZ. I may have to be the guinea pig and buy one so I can form my own opion and give feed back. When it comes to spending $130 for a battery though I'd rather be the follower than the trailblazer.
It was the best I had to offer.
Someones gotta go first. We're all watching.
and I appreciate your suggestion. I have been looking around trying to find more info but I have to admit the more I read the more confused I get.
After several e-mails back and forth, I finally ordered a 5Ah battery. I would have gone with the 2.5Ah, but since I don't have a kick starter, I have the piece of mind knowing that I'm not going to have any problems.
Anyway, I should have it early next week. I'll report back here.
Steve
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
