Spark Plug gap....
What is the recomended spacing on a spark plug for a 2007 cr125. I do not have an owners manual. :p And, does the amount of spark i get depend on the spacing?
thanks
Spark plug come pre-gapped unless they've been tampered with. At least every spark plug I've ever installed have.
.023-.025 in most likely
Plugs come pre-gapped at .028"
  • Similar Content
    • By Roman Krzyzanowski
      I have a 2000 Cr125r and I’m in the middle of rebuilding it I just put a new crank and new bearings and all new gaskets so far. I haven’t made it to the top end honestly I’m kinda stuck at this point I &%$#@!ed up and didn’t take pictures while taking it apart mistake on my end because I can’t even find any pictures or anything on it now. I already put the cases back together I’m now on the shift brake pause side I was wondering if anyone could help me with a few pictures of that side of the motor if someone had some? Or send me a link of a diagram of how it’s supposed to be and look. this is the only part I’m stuck on it’s pretty tricky but after that i just got the top end I really appreciate any advice or any pictures y’all come up with or diagram EVERYTHING helps I’m kinda dead in the water at this point ..
    • By 870
      I have a 2005 cr125 new to me. I had millennium tech replate cylinder and supply new piston. I replaced crank bearings and now it won't hit power ban. It feels like a 4 stroke bouncing off rev limiter. It is also putting a lot of black spooge out of exhaust i mean a lot. The plug is black. I cleaned carb and adjusted floats. I also repacked silencer. I noticed the carb leaking gas out overflow the other day. I suspect it is running really rich. I have a brand new pwk from Jd jetting I'm going to try out. I also did a leakdown test and it held. I also am not 100% sure the power valve is set up right. The manual doesn't go into great detail about this. But it seems like there is only one way to put it back together. I have the engine out I'm going to do another leakdown test and double check my power valve and put it back together with this pwk. Any other thoughts out there?
    • By rrrak86
      Hello all!! I picked this up yesterday.  New to me 1997 RM250.  It has Rockstar graphics on it and the guy said it's a Rockstar edition bike.  I can't find anything online that would give me any details.  It looks to have the correct graphics and the radiator shrouds are purple.  Any ideas where to find out the details for these editions?
    • By 101 2-storke
      I have a 2003 Honda CR125R and am looking to get an aftermarket break pedal. but cant find any that will fit my bike. so I'm wondering if one for a 2004 CRF250R would fit my 2003 CR125. anyone know if it will?
    • By aminem
      I have never ridden 2t dirt-bike , i start my dirt bike adventure this year with a 4t yz450 and i love this sport. now am interested to test 2t cross and want to use it for enduro and MX. are this bikes ( yz250) good for both enduro and MX use !? i heard that yz250 is the same from 2006 up to 2016 and have no change . what about honda cr250r !? which year and model of this two brand worth owning !?
