Making DRZ 400 kick street legal
Want to know if there is a kit or something to make my DRZ 400 kick street legal ? Any help would be great.
First need to find out what the DMV requires in your state.
Lights horn signals tail and brake light head light mirrors
Thanks, do I need a battery to run all of this or will the stater do it?
Here in Missouri if the MSO title states "For Offroad Use Only " Its pretty hard to get a title and registration, I would't say impossible though.
Utah was easy untill last year when gas went up and everybody dug though the shed to get there treasures. Now Utah says you need every thing.
Welcome to mass :p
Battery
You don't need a battery, presuming your state does not require the lights to be able operate for a period with bike not running (which most don't).
I recently did a home-brew project on my '02 DR-Z400 kicker, and in addition to blinkers front & rear, illuminated speedo, and a new brake/tail light, I installed a 55 watt H3 bulb in the stock housing. Works absolutely great. No flicker at all at low idle. Plenty of power generated by the 150w kicker generator. But, of course, when the engine shuts off, so do all lights. Which is no problem for me (or Alabama).
Procycle.us seems to have the least expensive kits, if you are not thinking about doing it yourself. If you have any interest in taking a look at the wiring diagram I drew up to make my kicker street legal, pm me with an e-mail address & I'll be glad to send a .pdf along!
Very best of luck to you. The kicker makes an outstanding DS platform!
check with Wheeling Cycle Supply, he has a pretty reasonable wiring harness and LED sigs etc. He converts E models all the time. Search the site here too a lot of guys have posted their plan for converting.
just make sure you don't need to stop your bike at night. If your engine goes and you get stranded on the road or road side no one will see you
I picked up a Baja Designs kit and a DRZ-SM frame on eBay.
New Hampshire just required me to put on the lights, headlight and tail/brake light and have a horn, air horn would be fine. I went with the Baja designs light kit complete with turn signals. I have an E model so I could have stayed with the stock lights. I just wanted to give the car drivers all the lights I could. Mine had an "off road only title" but I asked the DMV and they told me it just had to be inspected and I needed to bring a letter from the dealer saying it was road ready. You gotta love the "Live Free or Die" state.
  • Similar Content
    • By Markl5557
      Anyone’s air box smell like gas ? Is this normal ? Air filter is bone dry but it reeks in there .... I’m assuming cause of the carb being semi filled with gas ??
    • By Markl5557
      So I’m reading these horror stories of the stock vacume operated petcocks failing and letting gas into the oil .... how many of you guys switched over and is it worth it to switch to manual ?
    • By Markl5557
      Hey guys . I feel like I post here way to much lol
      anyway after having my bike kn it’s side overnight to fix a cracked stator cover .... I come to find out that I also accidentally left the pet cock in the prime position .... constant gas flow to carb ... now my oil smells strongly of gas ... my question is ... was it the bike being on its side that made the gas get into the oil or the prime position on petcock that made this happen ? Or both ? I didn’t ride it much at all after discovering... I assume. I should drain the oil obviously but any other suggestions ? Always appreciated -mark
    • By Praneeth143
      Hello guys , I have a suzuki drz400sm which is a 2009 model recently I purchased a rear sprocket which was a JT 41T , but I found that it did not fit to the rear sprocket hub of the bike and my drz has got the EXCEL TAKASAGO rims in it . How can I find one that fits and what sprocket brands and where can I buy it . I have attached pics of the current setup , please help me
    • By Surfman1
      Hello all, first time poster. Just bought this bike a few days ago it’s an 08 drz 400sm and am starting to notice it has a strange backfire at idle. I understand a little bit at decel might be normal, but at idle too?  It appears to have been jetted already, judging by the fact it has a jd jetting sticker on the bike itself. I know that it’s not an exact indicator it has but it could be. Has an FMF exhaust, it looks like a full system rather then a slip on but not entirely sure. A buddy recommended I mess with the air and fuel screw, haven’t done that yet. Just wanted to see if there was any other tips I should try.
