new applied clamps?
I just had my stem and bearing pressed on the applied bottom clamp today. When I put the stem and clamp on the bike tightened the nut the clamp is rubbing the neck of the frame. does anybody know if theres something wrong with the bearing or do I just need to grind a little off the clamp? it only rubs on the clutch side. but the brake side is very close. Any ideas please
the only washer is the one for the top nut. what would that have to do with the bottom clamp? the stem is in the clamp then the bearing is on top of the seal.
