E Model head Pipe Installed on S model
So I picked up an E model head pipe over the winter on ebay for $20 bucks shipped. I had read a little about the install, sounded fairly straight forward. Other guys had talked about taking in the stock muffler to an exhaust shop and getting the header opening expanded to accomodate the bigger header. I did this and it cracked the pipe :p
So the next day I took it elsewhere, had them cut off the cracked portion and weld a piece on to fit the E header. Went fairly well, pretty ugly weld though. Once I ground and painted it not too bad.
Finally get to take it for a ride:banana: A little disapointing, maybe I was expecting too much because I can't really say I notice a difference. I recently installed an FCR39 and it gave a nice boost, but the header, again no noticable increase.
For anyone who has installed the E header with the stock muffler have you noticed a difference?
I do wonder if the jetting has a big impact? I jetted to Eddies specs but for an aftermarket muffler. Eddie said 160main with current set up and 165 main with the KXF250 muffler I had planned to put on (wasn't as easy as I hoped) So I have the 165 main in. Bike seems to run fine but will I notice a power increase dropping to the 160 main? Is this why the E header didn't have the desired effect. Or as said before am I expecting too much?
I think your main is to big. Stock exh. 155 is recommended.
I have a full yosh with modded trc med. comp. s.a. 160 main.
I knew with a 2 stroke the smaller main when needed will give a crisper throttle respone but i wasn't sure if it would be the same with the 4 stroke. Like I said the bike seems to run good. Eddie had said go with the 160 main for this set up, only reason I put in the 165 cause I thought I would be putting on the other muffler. I think I will put in the 160 and try.
Main s/b a 155.
In the US, a S/SM muffler is the same internally as a E model. Both flow the same. I think this is the case in CAN too.
E header is good for about 1/2 Hp, too little to measure with a pat. pending "Butt-O-Meter".
New question following along the same topic.
If I were to install a slip on now that I have installed the E header, I would have to go with the E model muffler? Correct?
I've read about guys putting the E muffler on S models and just using one of the peg mounts to button it up? Is this accurate?
Pretty much. LOL, you could get a slip on for a S and expand it.... Keep in mind, the gains of a slip on are not much. Bang for the buck, a full system (MRD) is the way to go.
Is the MRD going to give you a noticable power increse with a stock engine? (engine is stock but I have the FCR installed)
I installed an e-header that i got for cheap on my sm. Maybe noticed a little in low end throttle response but i really didn't notice much. I've been told that the FCR will give you 3-4 horses and a full exhaust like MRD will give you 2-3 horses. Still waiting on parts for my new to me FCR 39 so I can get her mounted.:p
Main s/b a 155.
IS THIS TRUE FOR ALL E MUFFLERS OFR JUST POST 2007?
THE EARLIER E AND K MUFFS I HAVE SEEN FIRST HAND HAVE LESS BAFFLES INSIDE.
Hi Rob, :lol:
Sorry this is too late now, but just for information, there's two ways to expand the muffler opening. One way is a hydraulically controlled segmented piece that spreads out... usually too much. Not good.
The other way grips the pipe while a smooth bullet shaped piece slightly larger than the stock opening is hydraulically slowly pushed into the opening, gently opening it up only by that preset amount. Good.
I'm currently modifying another S/SM stock exhaust and had it done by the second method at a local muffler shop and it worked as smooth as silk.
Take Care,
Greg
So, in regard to the jetting. I went through my jets today and no 155, only a 160. I put it in and went for a ride. Now I understand the FCR hype!!! This thing rips now, it's a wheelie machine!!
So now the question is, do still try the 155 or stick with the 160?
Did I mention this thing rips!!!!!!!
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
