09 EXC 530 passenger pegs???
Hello, I am soon to be a new 530 owner this friday and cant wait!!!!! Has anyone seen any type of passenger pegs for that model or any pics of home fab jobs. Im thinking i might have to design somthing my self but hope not. Any help would be much appreciated. Thanks:ride:
You might want to look on KTMtalk.com I've seen pics of some fabricated passenger pegs on that site but nothing for that new of a bike. The problem is that the sub-frame really isn't set up for that much weight. There is no such OEM part that I know of.
try this thread:
Thank you very much for that link to the foot peg mounted buddy pegs. I was trying to figure out a way maybe of attaching some kind of arm to the ktm pegs that has a buddy rest,,,, and there we go. After i dump my piggy bank in to the purchase of my new exc tomorow I will be looking in to the buddy pegs for my wife. Thank you again.
Hi perhaps not too nice, but works very well for my wife but I don't run in the plublic road.
he remains me some modification has make.
a good day of the Quebec
steph, that's an interesting way to attach passenger pegs- i like it!
it got me thinking that you could have a similar setup except that it would fold over the main drivers pegs, kinda of like on a hinge. when you don't need them they are completely out of the way- when you have to give a ride, just fold them out and your ready to go!:doh:
My freind has an 08 and bought street bike buddy pegs and had to fab a mount to the subfram on the shifter side and in his case(no movement in right ankle) he mounted it where the rear brake resevoir & pedal would go since he now has a hand brake and rekluse clutch. u have to fabricate mounting points, its a little work to do it cleanly.
Bought a pair from tec-cycles. Used them for about 25 minutes. The girl hates being on the back...
Anybody interested in them please pm me.
My freind had to fab. his own mounts to the brake resevoir mount one 1 side and weld a tab to the sub frame on the shifter side. He used street bike pegs off a GSXR or Honda croch rocket street bike.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
