Adding spacers to stock springs?
What would happened if I added a 1 inch spacer to a stock for springs? I have a 97 xr650l that I got used. So I don't know what springs it has. I do know that they are to soft for my fat ass. 5 '10' 225 without gear. I am going to change out the oil soon so I figured what can I do on the cheap? I once heard if you add some spacers to the stock springs it help with bottoming out. Is this true? Thanks Guys Ben
All it will do is add pre-load. It'll make the front end ride a little higher, but the spring rate remains the same - which is apparently too light in rate for you.
The only (correct) answer is to install the correct spring rate.
Thanks I ordered some from race tech today. Ben
  • Similar Content
    • By Wade Beall
      I’m looking for stock rear suspension link. I bought my 2007 xr650l with a lowering link on it and I want to go back to stock height.
    • By faizakhtar125
      I've heard if you put VForce Reeds, properly jet your carb and clean the carb, change the exhaust pipe, clean the airbox and put a new air filter, and properly fix the shocks to match your weight, you can gain a ton of power?
    • By Alex Wren
      I recently bought 1988 xr200r forks to go on my 2002 xr200r (got them revalved for my weight and riding style), and I only bought the fork tubes. As I was trying to put them on l, I realized that they do not fit in the triple clamps of the ‘02 xr. What do I do? Please help!
    • By Alex Wren
      I got 2002 XR200R and I got ‘88 forks for it and they will not fit into the triple trees for they are too big. Do I need the triple trees off a ‘88 xr or is there something else going on with this.
      P.S. I’ve checked part numbers and everything is correct.
    • By 148am
      Make an offer, you pay USPS shipping. I want these out of my garage. Used, no damage.
      CST Suspension fork springs to fit 49mm stanchions in '03+ Suzuki DRZ400S, some KTM models, maybe others.
      503 mm length, 33.0 mm ID, 43.3 mm OD, 0.43 spring rate.
