small vibration noise
my 08 has a small vibration noise at mid to 3/4 throttle when i walk on it. i was wondering if anyone had the same problem and if they had a solution to it.
I had a vibration on my 07 as well... I traced it down to the rear spring flexing/vibrating...you may want to check it:thumbsup:
same here.. did it from day one... learned to ignore it really. I went over everything I could see and I've had the motor apart several times and everything is tight and what not and it still does it.
