Antigravity Batteries Giveaways: Winners Announced! Read more... ×
Just moved from sea level to 2200ft and my drz lost power
I have an 02 DRZ400E with a yosh TRC exaust. On Eddies advice it has a 48 pilot and a 165 main, and ran great in Victoria BC my old city which is sea level. I could get it to throttle wheelie in fourth with the right finess. Now i've jsut moved to edmonton AB with an elevation of 2200ft, and it boggs a little right when i first give it throttle, it idles slower, and is hard to get the wheel up in third, which was easy back in vic. Is this just because of the elevation change? What jetting should I change? both pilot and main? what to?? Help please I want my power back
Most likely. Higher elevation causes you to run a little rich. also, less available air = less power even when perfectly jetted
You should be able to adjust the pilt circuit with the fuel screw:
Fuel Screw/Pilot Jet
Fuel screw settings in the 'book' are recommended starting points. Every bike is different, as is the temp and altitude. Set the screw according to this method.
Gently turn the screw all the way in. Now back it out two turns. Start the bike and fully warm it up, go for a 10 minute ride. Set the idle to speed to 1,500~1,800 RPM as best you can (I know, without a tach this is tough, just set it to were it idles relatively smoothly). Once warmed, slow the idle to the lowest possible speed.
*** When turning the fuel screw, keep an accurate 'count' of the amount you are turning it and record it in case you have to reset it for some reason. Makes life easier when you can just set it from notes Vs. going through the procedure again.***
Turn the screw in until the idle becomes rough or the bike stalls.
if it stalled, open the screw about 1/4 more turn. Restart it and slowly screw it in till you can just perceive a change.
If the screw can be turned all the way in and the bike still idles perfectly and does not stall, then you need to go down a size in pilot jet.
Now very slowly, open the fuel screw till the idle is smooth. Blip the throttle, let the bike return to an idle, wait say ten seconds. Confirm it is the same smooth idle.
If the screw has to be opened more than 3 turns to get a smooth idle, you need to go up a size in pilot jet.
If you find it does not stall with the larger jet but has to be open more than three turns with the smaller pilot jet, put the larger one in and set the fuel screw at 1/2 turn.
If the idle speed increased, adjust the idle speed knob to return the bike to a real slow idle speed. You must then re-visit the fuel screw. Keep doing this till the fuel screw is opened just enough to provide a nice steady idle at the lowest possible RPM. Once this is done, increase the idle speed to the normal one for your bike, typically about 1,800 rpm, but go by the spec in your manual.
Then do the main:
Starting with the recommended main, remove the airbox door and go for a ride (bike fully warmed up). Is it better or worse?
If it is better, you need a smaller main.
Go down one size, replace the airbox door, ride. Remove the airbox door and test again. Better or worse? If better, go down a size again. Keep repeating this till the test with the airbox door is worse.
If it was worse with the airbox door removed, tape over 1/3 of your airbox opening, test (airbox door on, of course).
If it is worse now with the tape and was worse with the airbox door off, your main is just right. You are done!
If it seems better, you need to go up a size in main jet. Then test it again (remove the tape). Replace the tape, test again. If with the tape on it is better, go up another size in main. Keep repeating this till having the tape on is worse than with it off.
To finish up and ensure you are set accurately, retest the bike with the tape off (airbox door on), ride it, then remove the airbox door (tape off, of course). Best performance should be with the airbox untapped, airbox door on.
Remember, the main only operates at WOT. Ideally, you want to be in 3rd or 4th gear doing the tests, hitting max revs (just shy of the limiter) for at least 10 seconds to get an accurate representation of the jet status.
You may also have to move the needle clip a position closer to the top/flat.
