which plug
i have an 06 yz134 and i have always ran a b9eg plug in it but i noticed it calls for an iridium plug, would i have any benifits torun the expensive iridium plug.
They are supposed to be more durable and longer lasting.
I ended up getting several of them for 50 cents each. I would have never bunnied up the 9.00 for them. The sad truth is, they are probably worth the cost.
The bike starts better. I'm looking at 1-2 kicks no matter the outside temp. On some winter days it gets cold here...I started it in two kicks at 20 degrees.
ok i think i might try one and see ..... my bike always starts good any way usually first kick and i end up replacing the plugs when they are just wore out not because of fouling but ill give them a try
They are a little expensive to go all in with. I dont believe I will lose any sleep once I have to go back to the standard es models.
standard is es but i run an eg, is this fine?
Yes, no problem. Th eg is positioned as a better plug than the ES, but I dont think many of us believe it really is.
When comparing the EG to the ES, I have actually had better luck with the less expensive ES. So you can consider me one of the "many" you made reference to above.
  • Similar Content
    • By faizakhtar125
      Hey guys I read an article saying that the 01 YZ125 has six gears. But other people are saying that it's 5. How many gears does it have? Just asking. Thanks.
    • By idratherberiding
      2006 YZ 250.. The manual calls for 10w30 (yamalube 4 stroke oil), can I use 10w50 (Motul semi sythetic 4 stroke oil) ??   I bought the bike, want to change the gear oil before I ride tomorrow but all I have at the moment is the Motul 10w50  semi synth.  Is that oil going to be too thick compared to the 10w30 or will it be fine..  Thanks
    • By faizakhtar125
      Hey guys I just wanted to show off my bike and show it to the world lol  What is your opinion on it. God or bad, please be honest. I am open to all comments and suggestions. Any upgrades I should do to make it look better and/or faster?
    • By Allooushh
      I bought a YZ250F yesterday and the previous owner said apparently it runs but they weren’t strong enough to kick it. I couldn’t kick while there so I took their word for it and bought it. I’ve been trying to get it to fire all day today, there are 2 chokes and I’m unsure if the air mixture is correct, so would be nice to know what I should do, it’s hard to adjust the air screw when the bike won’t even run. I noticed the spark is kinda low, I don’t know if it’s normally supposed to be like that or not. I can see a blue spark but it is very small and crappy, I’ve had thumpstars that generated stronger spark, I changed the plug it’s still the same, so maybe could be an electrical problem, the only ground connection I could find was for the ignition lead which I filed down to bare metal so I’m pretty sure that connection is good. Anything else I’m missing? It’s very hard to kick and I can feel the compression out of the exhaust so I don’t think compression is the issue.Just wanna know what I should do, haven’t owned a yz before so I could be not using the choke right or something. Thanks
