1995 DR350SE rear sag setting
I just bought a used '95 Dr350SE and need to know the sag setting for the rear shock. Total travel now is about 5-1/4" (130mm) from unloaded (me lifting it up until the rear tire just kisses the ground) to me sitting on it.
What should I use for my initial setting?
You should have about 1 inch of static sag (no rider aboard), and 4 inches race sag (with rider aboard). If you are about 200lbs or more, you will probably need stiffer springs, front and rear. Racetech and others have online spring rate calculators to find the correct spring size.
