Recommended Trailer wheel Size?
I'm thinking of trailering a KLR 650 over the interstate :lol: . Some of the simple smaller trailers have really small wheels:eek: vs others with like 12" wheels. Are those little wheels safe for trailering on the interstate?:p
I reffer to the small wheels as "axle burners" for a good reason. Look for a 14" or taller would be my choice.
That depends on what you call safe. I consider them safe but problematic. I have 8” wheels on a small tent trailer and have had two tire failures in the last two years. This is contributed (IMO) to their light load rating (745 each) and hauling a near max load. My pop-up is 940lbs dry. This and a lack of quality tires available in the small sizes and the rough roads I travel on are what I contribute to the high failure rate.
The first was a bubble that formed in the tread and then wore a home through the tire and the other looked like the start of a tread separation but the tire started to loose air before the tread pealed. This time we where on a smooth windy highway and I could feel the sidewall rolling as we cornered and pulled over before the tire was completely flat.
Overall if you can get up to 14” wheels it’s a plus but if the deal is right and you aren’t afraid of changing a tire now and then small tires are a deal breaker. At least not to me.
I've run 20.5 X 8 X 10" tires for thousands of miles w/no issues. I run a three-rail trailer. It's a very wide, but short tire. Bigger than the 8" wheels, but same diameter as some of the skinnier 12" rims you see on some trailers. Looks like this:
http://www.trailerandtruckparts.com/205-x-8-10-Nanco-N-699-Low-Profile-High-Speed-Trailer-Tire-Load-Range-D_p_539.html
My old trailer had the little 4.80 - 8 and they ate bearings went through 3 sets in about 3 years, last spring i built a new trailer with 4.80 - 12 and they have been fine even after probably close to 10,000km's of service.
