WR 400/13:1 compression Wiseco Piston
I've just gat all my parts back to put the wiseco overbore piston in my 400. The only concern I had was:
Are you required to go to higher octane gas (I already use the highest rated pump gas) when you change to the 13:1 overbored piston?
Should I be mixing down race gas? This bike is for fast trail riding only.
I ended up at 14~1 on my 97mm kit (444cc).
I found on the dyno the bike loved pump gas.
Race gas offered a minimal gain in HP.
http://209.197.247.209/Dyno_runs/SFO_index.htm
I also ran 1400miles of baja mostly on premium pemex w/no problems.
If it is jetted right I wouldn't be concerned.
The yz-f combustion chamber loves compression.
I would also run the yz base gasket, or the cometic.
