Harnass Question
The race season starts this Sunday and I'm going to get the bike ready for "hard" riding one night this week. For those of you that have been through their harnass, did you take it off completely in order to inspect it or did you just finger through the bundles? I was thinking about doing some "drastic" changes to the harnass, but I don't know if it is a good idea or not. By drastic I mean, totally removing the oxygen sensor wires, removing the large connector near the head (not the D&M plug-in, the BIG one that sits to the left of the spark plug). I don't know what harm can be done by removing this unused connectors, I just want to know if anyone has done it already before I make the "big clip"
Leave it on the bike and double insulate the breakouts. Getting rid of the O2 sensor wires is a good idea though. I may make some changes to the relay circuit, add suppression, '03 switch, and a solid state relay to drive the fuel pump for better ECU protection.
I think you're the king of the cool mods ... but you need to document your (ie: understandable instructions/parts (and where you can obtain them)) mods.
I'm in exactly the same boat as Jason. Our season starts in 3 weeks and I want the Clatterdale to be bullet proof.
I've gotten as far as cutting the zip ties loose... then I lost my nerve. :D I've been 'studying it' ever sense. I'd also like to remove the clutter from the top of the head, and move the ECU plug in unit to the rear at the seat & rear fender. It appears that I could move all of it back to around the battery box area, maybe even by what appears to be a relay or solinoid of some nature beside the battery.
In order to do this though I'd have to split open the wire loom that the majority of those wires are grouped into. I wouldn't want to do that unless I could replace it though.
Glenn, you've mentioned that you found several potential problems when you went through your harness. Did you open up the looms and look over each individual wire, or just gave it a once over in its stock form?
This surely can't be as hard or scary as it looks...can it? :)
Look closely at the harness where "breakouts" of a smaller number of wires go to connectors. You will find these are unprotected, and frequently in contact with or close to the frame or frame fasteners. These are the wires you need to add insulation to. Also look for shiny spots on the frame, valve cover, etc. that indicate rubbing. Use zip ties/insulation/minor repositioning to eliminate this.
Potential trouble spots are:
unused O2 sensor breakout(heat)
upper subframe bolt area (insulate nut)
valve cover area (heat, abrasion)
stator connector (sharp bend, wires touch frame)
rectifier/regulator (sharp bend, tension)
throttle body upper right side (abrasion on throttle body)
fuel pump (tie connector to frame, eliminate flex, insulate wires)
relay, fuse area (many sharp bends)
The main loom is fine, its tightly wraped, insulated, and mounted to the subframe which is cool on the right side.
You can cut the sleeving and pull the interface wires back far enough to locate the D&M connector near the relay, just tape it up tightly and mount it back up. I did it with extended wires, leaving the harness intact.
Keep in mind whenever you have a wire with sharp bend in conjunction with vibration and movement, you are asking for a broken wire.
Overall try to eliminate stress, movement, heat exposure, and abrasion and the system will be 100% better.
I'm working on some other neat stuff using solid state relays. If space allows I will replace the existing one and add additional one to drive the fuel pump. Also re-plumbing the fuel system to allow a little more room for a bigger fan.
Hope this helps.
  • Similar Content
    • By beeboob00p
      Bandit 1200s
      Asking Price
      2200 OBO
      Contact Info
      281-731-86 three 9
      Howdy Everyone
      Today I am looking to sell my 2004 suzuki bandit 1200s for 2200 OBO. I have owned this for over 3 years and it was my daily the whole time. Yes, every day rain or shine. It never let me down and has been the best to me. I love it to death, but now that I have graduated with a big boy job that involves lots of travel. It is time to move on to something newer and more economical. It has loads of mods and general maintance parts to help it have a great life with me and continue on with it's next owner. Current real mileage is around 30k and the title is clear in MY NAME.
      Videos of start up and just it idling
      It was well maintained.
      Valve adjustments done early (will include special adjustment tool with sale)
      Holshot Stage 1 jet kit
      Holshot Ignition Advance
      Holshot Slip on
      New chain and sprockets
      New Spark plug
      New airfilter
      Renthal Handle Bar
      Shorty Levers
      Upgraded windscreen (great for long trips)
      Suspension Adjusted and dialed in properly
      Price is flexible
      Mileage is exempt (the speed sensor was broken when I first got it so it didn't record mileage until recently. Everything is now working properly)
      Has been down before (damage shown in pictures)
      Some other cosmetic issues from being used every day (general chips from rocks and small stuff you can't see in pictures)
      Windshield vibrates due to height
      Exhaust rattles a bit (will include new muffler mount bushing to fix this)
      I'm sure I'm missing plenty of stuff but this should be a great start on what this vehicle has to offer. If you have any other questions or would like more pictures, videos, details on anything please let me know. I'll be happy to work with you.
      At this time I am only looking at cash offers for the bike. No payments, sorry. Also I must note that no joyrides either. You bring the cash in full and I will let you test drive. You hold the title, I hold the cash. You drop it no harm done, because you keep the bike and I keep the cash.
      At the time of sale you and I will sign the title and we will fill out the proper paperwork for the transfer of the vehicle on the spot. Sorry, but I Have been burned in the past. Thank you for taking the time to read this and I hope you enjoy what you see.
      The best way to contact me is by phone. I'm not on this forum much, but feel free to text or call away and I would be glad to respond to any questions you might have. Thanks,
      -Frankie 281-731-86 three 9
    • By kashlak
      JUst curious of how many bikes,quads,trikes people owned over the years and what they were?
      78 honda atc 70
      85 honda atc 110
      ?? handa trail 70
      78 yamaha mx 80
      85 yamaha yz 60
      82 yamaha it 125
      85 kawasaki kxt 250 tecate
      79 yamaha yz 400
      86 yamaha yz 125
      85 yamaha yz 80 (playbike)
      92 kawasaki kx 250
      93 yamaha xt 350
      and last but not least a 99 kawasaki kx 250
    • By 450 vet
      what are some of you guys running for an exhaust? this is a busy section..lol
    • By s5201
      Wondering if anyone has ever converted a Cannondale to a supermoto?
