how much oil do i put in my 2005 rm 250?
Just fill up to what the case says.
The FAQ you are referring to is for an rm250 from 1989-1995 - not 2005.
huh? if you are referring to the bolt you take out to check level,mine is located on the right side in front of the clutch cover and is a 10mm bolt size instead of an 8mm like the rest of the bolts in the area.mine is a 00 rm250.
