Twin Air Question
Is anyone running the fire-retardant air filter? Is it necessary if you don't have a screen? Anyone using the Twin Air filter cage? Does it seal better? Does it have a screen?
okay, that's enough questions!!
I'm using the twinair with the screen stock cage and it is fine , it seals properly , much easy to remove and install than the stock . For the cage filter from twinair , it has no screen and there is a specific filter to fit on it which is different than the oem ones .
See ya
